SC300/400 Replaced Headlights and Blue Cut-off line
#31
Originally Posted by indypwr
you mean this.........?
now yours looks blue and IronCobra looks more of a green color still looks good but in one of the pic his passenger is much blue when the driver side is green then i guess he change it to both green, not complaining i still like it
#32
#34
looks pretty nice bro........good work!
my lights dont look like the ones i just posted. i used to have 4300k standard bulb (85122) before but i changed to (85123) bulbs. i have not taken any pics yet but accrdg to some members here that hs seen my lights, thy look more like benz ....a slight purple hue to it with 'white'....
i shud take pics one of these days...
#35
I'd like to see them. I was going to do a retrofit, but I had an old headlight that I tried to take apart and almost destroyed the thing trying.. I didn't want to risk it. Now that my new headlights produce a similar look, I'm not going to change them one bit.
Thanks for the kind words!
#36
Originally Posted by IronCobra
Here is a non enhanced picture. If you see any green, that is probably from the wall or the ambient lighting.
#37
I would have to say that my new OEM headlights are just as bright as a retrofit. I pulled up next to a new E500 Mercedes with HIDs and you could not tell the difference in brightness. My car actually created that "eclipsing" effect over his headlights when I was passing him. It was awesome. The cut-off line appeared to be just as good. I love driving down roads with trees on each side so I can see the clean cut-off line. I also had a friend who drove the car towards me and it was awesome to see the fluttering and light shift. I might try and film it if someone could host it for me.
This is an awesome OEM upgrade to do!
#38
I am thinking of ordering 5000k HIDs from Hella and was wondering if I would notice much of a difference in the color or sharpness if I used the different lens. They are bright white sooo..... would it add any blue? thanks!
#39
If you order new headlight assemblies, you should get a slight blue hue right on your cut-off line. I am running a 6000k kit and I get a very deep blue hue on my cut-off line.
#40
Finally have some good night pics!!!!!
Now this is a cut-off line!!!! This is what my headlights now look like!! The cut-off line is much sharper than what you see in the pictures, I had the exposure set very high.
#41
DAYMN!! looks nice!!
sorry if this is a dumb (obvious) question...so even tho these replacement headlights are for 97+ SCs, they'll fit on older ones right? I'm assuming yes, since I don't think there's anything different, but I thought I'd ask.....
#42
#43
I'd be interested in seeing what the actual difference is on the lense' contour, and whether or not it's just a polished version of the older lense(diffused/frosted surface).
In most lighting situations the sharp cutoff, and coloring is undesireable and tuned out with the lenses.
Great research on the lights.
I still want to see an Audi A8 LED headlight.
#44
