Mounting front spoiler lip on a 95 SC400
I searched, and couldn't really find a good write up / instructions / help with mounting the front spoiler lip on a 95 SC400 front bumper. Who has done it? How hard was it? I'm hoping to get put it on tomorrow, and then hopefully get it painted next week
TIA for any help...
TIA for any help...
The stock spolier comes with some retainer pieces and should have pre-drilled holes. They should also have some bolts on there as well. You can just line them up with your stock bumper and drill holes on the bottom. I used stickers to mark the placement of where to drill the holes. Place the retainer pieces after fitting the spoiler on. Then get some nuts and washers and screw them on the bolts.
I recommend removing the bumper first. Also get good drill bits and primer and paint before installing.
I recommend removing the bumper first. Also get good drill bits and primer and paint before installing.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
alright...I've found two threads regarding the removal of the front bumper...can anyone veriify that it's the same for 95-96 SCs? (I think the threads were originally started for 92-94 SCs) I'd like to do this myself, but I just don't wanna **** it up...
thread 1: https://www.clublexus.com/forums/sho...d.php?t=128298
thread 2:https://www.clublexus.com/forums/sho...0&page=2&pp=15
About the first thread: Those scans are probably from a 93-94 SC400 manual where the lip was included and the holes are pre-drilled for the spoiler. It shouldn't be any different except from 95-96 models. I've done it on my own car (96 sc300) and those diagrams are accurate. Just expect to remove a sheer amount of screws and clips. Not to mention some manual dexerity involved in removing the bumper. Siblings are always a good thing to have around
. Make sure you have enough clearance underneath and don't forget SAFETY FIRST!
I used an electric cordless swivel screw driver to remove just about every screw. And a rachet to remove the tougher ones buried near the headlamp and fender areas.
Pic of my painted lip to come ... once I get home
originally '95-'96 doesn't have a lip piece. It must be an after market spoiler.
The removal of the bumpers of all years should be essentially the same.
#1 - remove headlights
#2 - remove the screws on top of the middle of the bumper
#3 - remove the pop screws underneath each headlight
#4 - remove the screws near the corner lenses
#5 - remove the screws on the bottom of the bumper which attaches to your plastic engine covers...
Should be pretty easy and straight forward once you start taking things off...
Good luck!
cool, thanks guys! I (think) i might give it a try...for those of you who mounted the spoiler lip to a 95-96 SC, did you guys have all of the mounting brackets? I've got the center mounting bracket, which I heard is the most important....but I don't have the two little side ones. If you guys didn't have the brackets, what's a good idea on how to mount them? Any ideas on fabricating a mount? Just thought I'd ask all these questions before I start taking apart...
Another idea I'm having is that I might just bring the lip into a body shop (to mount it and get it painted at the same time). Just curious...what's a reasonable price if I decide to have this done? (I'm a little chicken when it comes to drilling into my car....
Time for a trip to home depot. Basically you need something long but somewhat flexible to reinforce the bolts and the lip. I think there are some pieces that are aluminum based and is pretty easy to drill through with the right drill bit. But it's a shame you don't have the side retainers. They are actually harder to imitate because they are already curved to the shape of the bumper.
I've actually took the liberty to ask a few mechanics in the area before doing it myself.![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
Average is around 60 bucks for the lip installed only (providing all the parts myself) but if they require the bumper to be removed, 60+75=135. Painted and installed is around 150 bucks for the lip alone.
