How to spend 5k
How to spend 5k
Brakes
Toyota Front Brake Caliper for 1993-98 Supra Twin Turbo - USA Spec Driver Side
Toyota Front Brake Caliper for 1993-98 Supra Twin Turbo - USA Spec Passenger Side
Brembo OE Replacement Rotors for 1993-98 Supra TT - Rear Pair
Brembo OE Replacement Rotors for 1993-98 Supra TT - Front Pair
Goodridge / SMC Stainless Steel Brake Lines for 1993-98 Supra
Suspenssion
Koni Yellow Adjustable Shocks for 1993-98 Supra//Rear
Koni Yellow Adjustable Shocks for 1993-98 Supra//Front
HKS SF5 Spring Kit for 1993-98 Supra/
DST High Performance Sway Bar Set 92-00 SC300/400
S1-2002A - Daizen Front Control Arm Bushing Set
S1-2003 - Daizen Rear Control Arm Bushing Set
Wheels
TT Supra Wheel Front
TT Supra Wheel Rear
Michelin Pilot Sport A/S (Ultra High Performance All-Season) Front
Michelin Pilot Sport A/S (Ultra High Performance All-Season) Rear
Suspenssion
Wheels
TT Supra Wheel Rear
wow, you're gonna love the improvements....brakes is one thing...and those Daizen sway bars is another...nice list of mods btw...
I on the other hand spent 5k this way (considering I already have supra brakes front & rear)
Tein Flex
Daizen Sway Bars
Bodykit
Paintjob
New Wheels
Tein Flex
Daizen Sway Bars
Bodykit
Paintjob
New Wheels
Chicago Lexus Club Moderator
Originally Posted by Goldark
Brakes
Suspenssion
Wheels
TT Supra Wheel Rear
Suspenssion
Wheels
TT Supra Wheel Rear
The springs are made for Supra which is 3400 lbs. They will sag. The Koni suspension with Daizen control arm bushings will make the ride very hard. I know because I have something simmilar and it is not a combination.
Your ride quality will go down the tube. Even a streight road will be bumpy.
Chris
Originally Posted by AutoCoutureSC
that's a huge list of mods.... for both of you!!!!
dont' forget pics!
and Tony, hit me up when your car is out of the shop. You know it's time for another photoshoot!
dont' forget pics!
Makeover Tony??!!
Wow, I gotta see this....
if maintenence is right I would do two things and call it quits for a while...
1) Coilovers
2) Proper fitting wheels (wide with low offsets...)
You can transform a car with only those two mods into something that will make people stare in awe!
1) Coilovers
i think if i had 5k to spend it would absolutely go towards a boost logic turbo kit.
i think this what you should do personally. I think start with the tein type ra coilover kit you'll love the coilovers. then start by doin the brakes. and to end it all the supra rims with pirelli assimetricos. those tires are my choice. the reason the coilovers is for adjustability and coilovers tend to ride well. the daizen products are good choices but i think you can hold off on those produst for a bit. and make sure whatever mod you do. do it right the first time like the suspension. dont waste your money on a shock and spring kit if you think your goin to change it later.
i'm with him..... i've learned my lesson after switchin out suspension parts like three times i think. and i just blew 5.1k already too just like you..... cept the list is like just one thing, rims wit tires.
Brakes, suspenssion, and wider wheels should be done prior to getting more horsepower.
Ronsully
Suspension and Brakes
01-06-06 09:05 AM
SpdRcr0
11-11-02 05:03 AM
