I need help in Installing windshield washer neon on my sc300
Zombie Slayer
Originally Posted by ifilrx
guys, i'm wanting the look of neons...not functionality.
I think everyone here understands that ifilrx. It's just that the general consensus here on CL is that the neon washer nozzle mod does nothing to enhance an SC. Ultimately, it is your vehicle and you should customize as you see fit. Look back over the posts and you will see that other members have given you the instruction to properly remove and reinstall new nozzles.
After you're done, post up some pics. Defend your case that they work on the SC. Maybe you'll actually convert someone!
Originally Posted by mkorsu
I think everyone here understands that ifilrx. It's just that the general consensus here on CL is that the neon washer nozzle mod does nothing the enhance a SC. Ultimately, it is your vehicle and you should customize as you see fit. Look back over the posts and you will see that other members have given you the instruction to properly remove and reinstall new nozzles.
After you're done, post up some pics. Defend your case that they work on the SC. Maybe you'll actually convert someone!![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
.......... an SC?? its a luxury car.
Anyway, the credit card method works. Try it.
I also changed mine, but used ES nozzles.
Ed
Originally Posted by ACleanSC4
just get some newer model washers instead of the neon, GS430, LS430...the GS430 has 3 nozzle sprayer, the LS430 I picked up has one rectangular nozzle...it sprays so wide it goes off the sides of the windshield!!
Cost is about $15 or so each and comes painted in any new factory color...best bang for your buck!!
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
hey guys, do any of you know how to put the LED tire cap lights on your tire air nozzle? I purchased some at pepboys and i'm wanting the look of LEDS...not functionality., they also match my hubcap spinners.
Jonny
It depends on which caps you got. Hopefully you got the red/blue alternating ones. Be sure to torque them down to 45lb.ft. of torque or else your muffler bearings might go bad. Goodluck.
winter4w
14
08-09-17 04:24 PM
joshoowa
02-02-04 05:06 PM
