Single-Stage 3-spoke airbags
Originally Posted by kaotiq
Is it possible to just hack the wiring together? They are just different harness plugs?
Originally Posted by RR-SC300
got a part number? and does anyone know for sure if the 2000 celica airbags are single stage?
i dont know if this is true or not. but to tell the difference from single stage to dual stage airbag. on single stage theres only one yellow harness adapter and on dual stage theres two separate adapters.
heres how a single stage airbag looks like. look at the harness its only one yellow adapter.
heres how a dual stage airbag looks like. is has two harness adapters.
you guys see the difference i hope this helps and is correct. anyone feel free to correct me if im wrong.
2000 airbags are single stage
Yes.... the top pic is single stage and the bottom is dual..
The "SQUIB" adapter can be purchased trhough Elmhurst Toyota from "Curt"
Costs about $20 and is needed for all "newer" single stage since the
harness is slightly smaller than our bulky ones. As mentioned they
can be re-spliced but I prefer not to play with airbag wiring and for $20 ... why?
BTW.... I believe all IS300 airbags are single stage as well... I know the 2002 are..
Originally Posted by 0l33l
Oh yeh... do the cruise controls work?
you to remove your cruise switch and reinstall on new wheel... very easy job
Originally Posted by silversprucesc3
Cruise and airbags are not related.... Some wheels may require
I see that www.car-part.com has a lot of celica steering wheels (-BLK LEATHER,"GT-S" TYPE). I wonder if they include the airbag and the horn cover.
I cannot find the part number nor the year of my celica steering wheel.
You should contact Curt over at supraforums. He will ask you to read off the part number on your celica steering wheel and will then match the adapter.
His contact info:
630.279.2265 parts direct
630.835.0122 parts fax
eparts@elmhursttoyota.com
www.elmhursttoyota.com
440 West Lake St.
Elmhurst, ILL. 60126
His contact info:
440 West Lake St.
