4 studs broke off my wheel lastnight
Apart from replacing the studs, I am almost certain there would have been other damage ... imagine wheel coming off and the inertia trasfer inside the whell well ... and the rotor nose diving into asphalt. ... not pretty!
Salim
Salim
Originally Posted by blksc300mt
ive changed em on an sc before...its so easy...theres a certain spot on the spindle thats got clearence for the stud to come out i believe...just rotate the hub until it lines up, and you can push the stud out of the hub...
Originally Posted by corkycal via PM
i was going through some old post and came across a picture of your rear brake with the studs.
i want to replace my studs in the rear and was wondering if the brake pads need to come off or can the old and new studs be positioned at one point.
thanks,
calvin
thanks,
calvin
IS3003o3
IS - 1st Gen (2001-2005)
05-24-11 02:16 PM
EddierRo
04-01-09 07:17 PM
chubby
CL of Southern California
07-19-07 01:30 AM
