10.6 on 20psi run
Finally got a chance to do a couple test runs at the track. This was my first time trying to get this setup down the track, so it took some getting used to. In this run, I misshifted to 2nd and ended up on limiter and let out and laid back into it. I never got a chance to make a pass on high boost (30-40psi) but that'll come soon enough! I did drive 30 on the street, and it's fun ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
video: http://www.turbo6.net/media/turbo6%2...own%2010.6.wmv
more pictures and videos of turbo6 turbo lexus sc300 - www.turbo6.net
125-130 , I don't remember exactly.
60' was 1.5 - it could go faster but needs more boost or bottle, the power just wasnt there at 20psi.
1/8 was 6.6
I was worried about the stock suspension bottoming out , but it drove perfect.
The car was running out up top due to so little boost, and I still need to spend a little more time on the tune as it changes from 11.5AF to 10.5 AF near 6500rpm
1/8 was 6.6
Congrats
That's awful quick for 20psi!
Let me ask you, how did you mis shift 2nd gear...you have th400 right? 1-2-3 straight back?
1.50 60' is no joke
How much did you spray it on the line? Big improvement over the 60's you were cutting just a short while ago
1.50 60' is no joke
Originally Posted by PHLSingle
Congrats
1.50 60' is no joke
How much did you spray it on the line? Big improvement over the 60's you were cutting just a short while ago ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
1.50 60' is no joke
As for spool, I was using a 75 shot off the line. The biggest thing that helped was having a working turbo, something my original turbo I bought from SP was not. I was leaving the line at 4300-4400 & 9psi, I think more bottle and/or boost will allow for better than 1.5 60's. Traction was 100% on current settings.
![](http://tmp.turbo6.net/datalog%20misshift.jpg)
