The complete headlight HOW TO clean DIY + projector refinishing
#64
I was wondering if there is any preventitive measures we can take to make sure the outside doesnt yellow up again. I was thinking of maybe tinting them with a really high percent tint, so it would still give uv protection but not dim the lights beam too much.
#68
I'm in the middle of doing this right now. I took them apart about an hour ago. I'm adding an extra step to the process. I have the outside cover soaking in a detergent cleaner overnight. That should remove the yellow tinge they have. Then I'll just polish them before putting it back in.
The lens wasn't dirty at all. I still have that soaking in the detergent overnight as well.
thanks for an exellent write up.
#71
Originally Posted by 1badceli
This might sound funny but...do we pre-heat the oven?!?!
#72
yeah defintely preheat the oven .. also don't leave it in there for more then 3 min at a time. otherwise the rubber hosing that is still on the light will start to melt.
I'm going to reglue it with some silicone sealant. Didn't have a chance to pick it up today. Will try to do so tomorrow.
#74
my head light has water in it. it is all fogged up and you can even see drops of water on the inside. can i fix that? im guessing theres a crack somewhere and water got in, can i do anything? can someone please also tell me how to take the headlight off my car? its the driver's side and i was messing around with it for a few hours with my old crashed SC and couldnt take it off
#75
In your wheel wel there is a plastic in fender piece that goes along the whole inner fender. You will have to remove that then there will be like (2) 10mm bolts back there that will need to be removed. Then there should be (1) on the top in plane view that will need to be taken off as well. Then vwalla..
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
