Having trouble removing paneling
Allright guys I unscrewed all the screws that are needed to remove the driverside paneling where the fuel/trunk switches are, but can't fully remove it. I got the side left of the steering wheel removed, but am having big trouble removing the paneling on the right side. There seems to be a problem removing this around the key ignition. It seems like this piece continues on above and to the right side of the climate control radio. This is a separate piece I know but in order to remove the paneling underneath it I have to remove this piece that covers the key hole and the area around the climate control. How do I remove this paneling without doing any more damage. I have a feeling that I bent some of the panels a little too much. Somebody HELP and if you can give me some diagrams!
-Justin
-Justin
You don't have to remove the seats to remove the center console do you?? Thanks. If so, I have no idea how to remove the front seat. From what I've been told there are 4 bolts; where are these bolts? Thanks in advance. Take care.
-Justin
-Justin
