Pics of SC with pulled fenders? (Detuned)
#46
ok might as well. lots of work still needed !
Still to come install Daizen camber bushings for more neg camber, JIC sides/rear paint and install, emblems, repaint hood + lip + trunk etc etc
Weds Kranze Cerberus II SMB finish
19x9.5 +2 MID, 11mm spacer, Falken Azenis ST115 225/35/19
19x11.5 +1 SLo, Toyo T1S 275/30/19
#50
[/QUOTE]
Wow...minus those exhaust tips.....wow wow<<clapping his feet and hands>>does anyone have any more pictures of this car?
#51
that before pic reminds me of the mid and earily 90's in atlanta when no one had 20's they just used small wheels and stuck them way out to the side and didnt put any effort to make the fenders cover the wheels.
and ive got a question how are the falken tires?
#54
I own a fender roller. you can rent it from me and do it yourself.
keep in mind, when rolling fenders, you must use a heat gun to prevent the paint from cracking and you MUST have patience.
#55
I pulled and rolled mine myself, a shop in melbourne has a puller and i used a piece of wood, shop rags and a BFH to do the rest. The back came out unscathed, the front lost some paint.
#56
sure thing
#57
Mortgage Slave
And you're a nut fitting wheels with them specs, my hat goes off to you
#59
thanks guys. still lots of work to be done. No rubbing at all. Removed fender liner, rerouted harness that was around the washer bottle. Yes I am a nut!
The Falken ST115 is a great tire I've used them on a previous car before too.
