Door removal
I got a new drivers side door hinge and was about to remove the old hinge when I noted that the door harness passes through the hinge. This means that I will have to remove the harness from within the door or from inside the cabin.
Which side is the harness plugged into? and how difficult is it to get to.
Originally Posted by nasc300
Thanks, I was hoping I did not have to remove the door panel.
I hoope the door panel does not fall apart it does not look or feel too good.
jonny
Originally Posted by vredniykot
that harness is about 10 plugs inside the door but only 1 or 2 plugs inside the kick panel (next to the fuses)
you do the math![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
you do the math
I was hoping I could unplug it from the kick panel but did not get a chance to look at that. I sould get to the garage on Saterday to replace the hinge.
Originally Posted by Dx3
While you have it off - brace up the door panel from the back to regain its structural integrity, somewhat
jonny
jonny
