Hood Weight
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
David,
I searched the SC forum and found a lot of posts with 'hood weight' info in them.
THis one seems to have most straightforward answer
https://www.clublexus.com/forums/sho...ht=hood+weight
Dry Carbon/Carbon Fiber/ FRP Hood
stock hood weight: 58.6lbs
dry carbon hood weight: 20.1lbs, saves 48.5lbs total (VERTEX)
carbon fiber weight: 22.9lbs, saves 35.7lbs (VARIS)
FRP hood weight: Unknown (VARIS)
Originally Posted by dhnash
In the message Roo originally posted, I believe the weight difference between the stock hood and the CF hood from Vertex should be 58.6lbs -20.1lbs = 38.5lbs instead of 48.5lbs.
Thanks Dave,
The 2UZFE Iron shortblock is about 82 lbs heavier then the 1UZFE shortblock. I was thinking by changing stock hood to CF hood will reduce some weight.
