SC- 1st Gen (1992-2000)
window weatherstripping
Old 12-24-05, 10:25 AM
lexsc492
lexsc492's Avatar
Default window weatherstripping
i have a 92 sc400. my windows are slow moving up and down and i think its mainly due to the old dried up weatherstripping.
who knows where to buy new stripping and how much
or how to replenesh, remoisturize the old rubber?
Old 12-24-05, 08:29 PM
duckworth
duckworth's Avatar
you can try belt dressing, but really, replacement is the best fix.........and if you have tint on your windows, then i'd not do anything but replace the weatherstripping or belt dressing, wd40, etc, may cause the tint to peel a bit
i'd go to the dealer, i haven't found an online source
honda has hondaautomotiveparts.com and i'm sure lexus has something along those lines.....i'd like to find an online dealer if they do.........
Old 12-24-05, 08:49 PM
lexsc492
lexsc492's Avatar
i plan to tint the windows this week or next but i think they will open and close even slower.. how would you apply the wd-40? also both inside and out?
Old 12-25-05, 08:10 AM
RGW LLC
Former Sponsor
RGW LLC's Avatar
most time it's NOT the weather seal...it's the motor/regulator on their way out.....thanks
Old 12-25-05, 05:21 PM
T0ked
T0ked's Avatar
Yup. Slow movement of the window is likely due to failing motors. Faulty weather stripping will likely result in sticking windows or screeching as the windows come down. I used some Vinylex or leather cleaner (something very gentle especially because of tint).
Old 12-25-05, 08:38 PM
duckworth
duckworth's Avatar
but if it's moving up AND down slowly, then that's a sign of sticky weatherstripping.....the motor may be going bad, but normally they don't do it gradually......gravity helps pull it down and keep it from going up as easily when the motor is on the way out, but sticky weatherstripping will grab it whenever.........it can actually cause enough resistance to make a motor go bad........
just roll the window down, spray wd40 in th channel near the front/lower part of the weatherstripping (where the window actually sits in the weatherstripping) and if that helps, it may be your only problem.....it normally catches in the vertical part up front where the window makes contact first.....
Old 12-25-05, 09:46 PM
lexsc492
lexsc492's Avatar
ye i will do that tomorrow... i love wd40 it works miracles.... my door hinge was popping when i open it and i sprayed the ish out of it with wd40 and now its smooth as butter and no pops
BatmobileX
RX - 3rd Gen (2010-2015)
11-17-22 12:40 PM
flektone
09-13-10 10:04 PM
GS300 I6
CL of Southern California
22
03-27-09 09:16 PM
lilthanh19
Automotive Care & Detailing
12-27-07 06:08 PM
rra640
10-10-06 11:39 AM
Quick Reply: window weatherstripping
