I need help changing my bulbs on my headlights
I need help changing my bulbs on my headlights. I dont know how to get to my parking lights on my '93 Lexus SC 400...someone give me some advice...Thanx
which bulb? You have the side bulb on the bumper cover then you have the headlight bulb.
The headlight bulb is simple so I'm asuming you refering to the other one. I simply took the bolts off around the liner inside the fender and changed it from the back.. at least that's what I think I did
it's been a while.
nevermind, found it by searching:
https://www.clublexus.com/forums/sho...=parking+light
Right next to the main headlight bulb (a 9006 bulb), tucked in slightly there is a small off-white colored plastic dip-stick type thing. It's around 2" long if memory serves.
twist it about 90 degrees, and it should pop free. IIRC, it's 194 bulb.
Its there next to the 9006 bulb... just VERY hard to get to. You'll eventually get it. Good luck!
While you are in there get two 9005 bulbs and mod them to fit into the 9006 socket, you will see a noticable difference. Its not night and day, but its helps.
Search google for 9006 to 9005 mod
jashtiani
11-10-15 06:50 PM
ThermonMer
11-12-11 01:29 PM
