How to change steering wheel on sc300
How do you change the steering wheel on an sc300? Does someone have a write up on how to do? Need help please. Thank You
PS: I did search, but couldnt find any "How To"s on changing the steering wheel.
1) Disconnect battery
2) Remove airbag fuse
3) Using a flathead screwdriver, pop off the two rectangular panels on each side of wheel
4) Unscrew the hex bolts on each side
5) Gently pull the airbag from the steering wheel until you can reach the plugs
6) Unplug connectors for airbag and cruise control, and set the airbag aside
7) Loosen the center hub bolt (but don't unscrew completely)
8) Pull/tug the steering wheel for a good workout until it hits the loosened center hub bolt
9) Finish unscrewing the center hub bolt, and pull the steering wheel completely off
10) Put the new steering wheel in, plug in all connectors, screw everything back in, reconnect fuse and battery.
11) Fasten seatbelt
12) Drive!
11) Fasten seatbelt
12) Drive!
Originally Posted by spheezy
if u do the steering wheel change do u keep the Cruise and Power Tilt functions?
11) Fasten seatbelt
12) Drive!
11) Fasten seatbelt
12) Drive!
Batmobile
10-27-22 01:57 PM
