Timing belt!
Hi Tom,
If you are at the 90k mark I would go ahead and change the Water pump also.
It is in the same location as the timing belt and actually is primarily ran by the timing belt. It is a lot better than tearing the front of the car down again later due to a bad waterpump.
BTW, I have all of the stuff you need, factory Toyota parts. I was going to change it on a car I had but I sold it first. I have a factory Timing belt, Factory Lexus Water pump, and the factory o-rings you will need.
I paid $240 for all of it. I will sell it all for $200 if you want is.
If you are only at 60k I would not worry about the Waterpump unless you normally put a lot of miles on your car in a short period of time. With out a replacement it will go out at 100-120miles almost guaranteed... I have heard from Service friends at Lexus.
I have been waiting to change one for a while, but I have always sold the car before they need it. My SC has 63k miles, the timing belt still looks great so I am going to wait until 90k and change both the timing belt at the wp.
Good Luck,
Scott
wscottwilliams@home.com
Good Luck,
Scott
ilcitdream
10-05-15 09:01 AM
