SC- 1st Gen (1992-2000)
Please help....Fuel Gauge
Old 09-17-04, 08:38 PM
0l33l
0l33l's Avatar
Originally posted by LexAnt
here's a lil update to my situation.... this'll be a brain teaser for you guys
when i start the car up, the needle will slowly go down all the way to E... then after driving for a while, mainly above 20mph, the needle will start to creep up all the way to F. However, this happens even when i'm not on a full tank. At this point, the needle just stays at F, never moving up or down. Then after i shut off the car and just leave it for a while, the cycle begins all again.
I also checked the needles... took off the needle to see how the three prongs/connectors reacted, same habit, it'll go down to E.
Brain Teaser start................. now!
Ditto on that The needle moves all the way around, but is never acurate. It shows me full when I've got 1/2 a tank left
Old 09-17-04, 08:44 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
ok so cant blame the needle, can't blame the sensor since someone has already replaced one. I'd say the motor, but the only way to truely tell is to see the unit hooked up on ANOTHER SC and see what it does. if you want to send it over to me i'll plug it in and verify.
Old 09-18-04, 01:09 AM
vredniykot
vredniykot's Avatar
i know when i took the needle off and put it back in on my gauge it did the same thing - stay on E
i swithched it around and it worked ok afterwards
what do you think Bryan, could that be it? or is it just power for the needle's light?
Old 09-19-04, 08:33 PM
LexAnt
LexAnt's Avatar
yea i'm with ^
after switchin the polarity on the temp needle, the temp needle read one line too low... so i switched it with the fuel needle after seein that the temp needle was causin the motor to read low. lo and behold, the temp gauge with fuel needle reads exactly what it's suppose to be at. However, the temp needle on fuel gauge is a different answer. The needle actually goes to the spot it should be (ie when i have half a tank it's at half a tank) but the problem is, it'll only go there after about 15minutes of driving so basically it'll work when driving on the freeway. but the moment i turn on the ignition (with or without starting the car) the needle will begin to drop all the way to E. It'll be like that until i hop onto the freeway for 15min and then it'll go up to the reading it's suppose to be at..... i'm guessin a connection? but i have no idea reallie..... any other possible explanations?
Old 09-19-04, 08:45 PM
0l33l
0l33l's Avatar
yea i'm with ^
I think that the manual said that the needle will not move when you turn the car off. Of course I could be wrong
Old 09-19-04, 08:57 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
In such cases the needle is usually off center on the contacts causing a weight shift, sometimes re-mating the needle with the three contacts causes this to correct itself.
Old 09-19-04, 09:03 PM
0l33l
0l33l's Avatar
I get this sometimes too. Sometimes the gauge shows correctly (I think) and sometimes it doesnt Most of the times it doesn't. I need to send you my cluster
Old 09-19-04, 11:22 PM
LexAnt
LexAnt's Avatar
remating as in takin off the needle and putting it back on? if so i've tried that about 5 times already...if not could you explain how to do it? cuz it sure is kinda scary driving from school to home (sj to sf and vice versa) with the needle on E and not know how much gas is really there til about 15min on the freeway.
Old 09-19-04, 11:30 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
15 min is too long. sounds like a slow to read sensor to me. JMO.
Old 09-20-04, 06:36 PM
LexAnt
LexAnt's Avatar
yea, before i did anything to the cluster, the needle would stay where the gas level is after i turned off the ignition and it would always stay there whether car on or off or ignition on or off. now my problem is that when i do turn on the ignition, the needle floats down to E, and it doesn't go back up to the gas level until either i'm above 2k rpm, basically on the freeway, in which case it goes to where it's suppose to be and then starts working even when i get off the freeway.
i'm just sooo stumped right now i feel like banging my head on a wall or table.
Old 10-02-04, 03:46 PM
LexAnt
LexAnt's Avatar
wooo fixed it..... dunno bout how your's all started but i just checked the connections on mines... noticed the motor wasn't fully in towards the center of the cluster so i pushed it in after unscrewin those screws on the back... double checked made sure there wasn't any gap between the motor part and the display part... then when i plugged it back in, i made sure to hear a clip from all three harnesses.... and it works!
Old 10-11-04, 04:47 PM
0l33l
0l33l's Avatar
Just replaced the fuel sensor with a new 100% Genuine Toyota part. Looks like it did the trick My mechanic charged me $127 for it and another $20 for install. Went to the gas station next door and filled up fully and I got the gauge to go from 0 to 110%.
Old 10-11-04, 08:03 PM
mikeloc24
mikeloc24's Avatar
So the one Tony sent you wasn't working or what? Because I thought you changed that part initially. Just curious.
Old 10-11-04, 08:29 PM
0l33l
0l33l's Avatar
I guess it didn't work My mechanic changed it and the only thing that worked was the light for when I need to refill. So my mechanic ordered the new part and now it seems to work. Before I filled up the needle was fully down, and after I filled up, after about 4 min of driving, the needle went fully up.... so I guess it was the fuel sensor.
Old 10-31-10, 02:09 AM
KahnBB6
KahnBB6's Avatar
Received 1,239 Likes on 866 Posts
Sorry to bring back an old thread but I am trying to fix this inaccurate fuel gauge problem on my 93 SC300.
Does anyone know if the "fuel sensor" that solved 0l33l's gauge issue also referred to as the "fuel sending unit" (the sensor located in the gas tank itself)?
Based on the gauge behavior he and others described in this thread I am pretty sure my car has the same condition.
Quick Reply: Please help....Fuel Gauge
