SC- 1st Gen (1992-2000)
Vent next to keys
Old 03-09-06 | 01:12 AM
SCoupe's Avatar
SCoupe
CL Folding 25,000
Originally Posted by pcmw
...sensor ...if you unplug it like I did, while installing my autostart, it will drive you nuts.
Hey pcmw, what would be a good indicator of this thing being unpluged? Ever since my 2jzgte swap, the system is heat all the time unless I put on "max cold" setting, then it will kick off the heat. Its that or vaccum hoses botched up.
Old 03-09-06 | 05:38 AM
933005spd's Avatar
933005spd
The solar sensor is a photodiode which depending on light intensity adjusts the Air mix control servo motor. If that is disconnected then you probably wont be affected too much, maybe on really sunny days you will need to turn the temp lower to get to a lower temp.
If the cabin temp sensor (vent thingy) is disconnected then you may encounter what you described.
If the auto light sensor is disconnected (clear sensor on US drivers side) then your lights wont turn on/off automatically.
There is an additional ambient temp sensor which could also cause that prob.
Peter
JPL20
RX - 3rd Gen (2010-2015)
10-19-18 07:27 AM
ardano
Performance & Maintenance
11-25-08 02:31 PM
PearlLex
06-21-04 12:31 AM
SC300Es
02-24-03 11:19 PM
Neal Rikal
12
07-02-02 06:09 PM
