Mini photoshoot after wash/wax!
Looks damn good.
Are the brake lights factory for like the 94-96 or something else? The are cleaer than my 92 tails..... The spray can job looks like a good alternative. My front/rear bumper is fading just the same.
What mods does it have right now?
![Driving Skid](https://www.clublexus.com/forums/images/smilies/drivingskid.gif)
Originally Posted by 4urxtc
Looks damn good.
They are 92 tails with the diffusers inside removed. Its about the hardest, messiest job in the world (takes about 2hrs per side, cant oven must use heat gun). I went to my local auto paint store and they pre-mixed the automotive paint and filled it into spray cans. It comes out good, i did not have time when i did it to sand down the bumper good so its kinda bumpy.
Mods are:
1992 Toyota Soarer Generation II 1JZ-GTE engine and transmission
Titan Motorsports Adjustable Cam gears
Injen intake custom made for 1JZGTE
K&N Filter
HKS Fuel Cut Remover
GReddy Speed Cut Remover
B&M bar and plate transmission cooler
Autometer Boost and Water temp Gauges with custom A-Pillar mount
MKIV Supra TT all metal replacement radiator
Custom upper radiator hardpipe
3800CFM 2-spd Ford elec fan
MKIV Supra 2JZGTE water pump
Toyota Soarer 255LPH fuel pump
NGK 6097 Spark Plugs
Daizen Urathane bushings all over
Koni Yellow adjustable shocks for MKIV Supra
Intrax Lowering springs for MKIV Supra
SSR Varden Sport Schwartz 3pc Forged 18in Rims imported from Japan
Silverstar Low beam headlights
Fog light mod with amber bulbs
Modified 1992 tail lights
M3 style rear lip spoiler
Ceramic coated turbo housings and y-pipe
Alot of PowderCoating
I probably forgot some stuff...
The cusco cage is the biggest waste of money. Unless you get the safty 21 cage, it's pointless. it's not scca approved, or NHRA. ****, bithlo wont even let you run a bolt in cage if you run 11.99 or under.
Anyway, pm me when you go single. I'd like to run you since back in the day you said a 2jz was a waste and your car will make the same power mod for mod as mine will.
PS: I like crooked stickers![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
**forgot to add....goodluck getting inners from SSR for those wheels since they are old and SSR went out of business a couple years ago. They're now back up and running, but by new owners.
You can, however, send them to weld craft wheels and get them widened. My brother sent off his 350z track wheels and had a 2inch band welded in place. from 8.5-10.5 in a week.
Some might not like that idea, but weldcraft has been around for a long time and have been doing this for years without any problems. ASk the supra guys with the stock tt wheels that are 10.5s or 11's
Some might now like that idea, but weldcraft has been around for a long time and have been doing this for years without any problems. ASk the supra guys with the stock tt wheels that are 10.5s or 11's
As far as that shell you are selling, are u willing to take instant lowball cash offers?
I recieved a deposit on my car and the guy is coming next week to pick the whole car up. I ended up getting 19,500 for it, but I'm having second thoughts. I just think I'll miss it way too much.
Peter
Peter
Peter
Peter
Yeah man that car is beautiful even without paint
