Mini photoshoot after wash/wax!
#31
Originally Posted by VJ RC51
They are 92 tails with the diffusers inside removed. Its about the hardest, messiest job in the world (takes about 2hrs per side, cant oven must use heat gun).
#32
Originally Posted by 4urxtc
That is alot of mods ... I like those tails alot but, why can you not oen roast them? I figure they would work kinda like the headlights. If so could you do a right up or atleast let me know what all you had to do. Thanks Good luck with the single snail. ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
I really havn't even started to mod the car yet. I'm having problems with the ECU when i goto upgrade to a single. Ive personally seen problems with emanage ulitamate on a 1JZ, timing advance is like 3* no matter what ecu setting. A single turbo 1JZ mk3 made 20 more rwhp then me on stock boost and they were in the 18psi range with one.
AEM wont warrentee a custom install'd ecu. The only proven system, FconVpro, no one in FL tunes them or has the unlock to do so (that i know of so far). Haltech is old technology but works, maybe microtech?
#34
If you oven roast the tails, you'll deform them. Its a different glue then the headlights, and ALOT more of it. It has a very high melting temp and cools very quick. I had problems with slight deformation using a heatgun, but youll never see it. Its a mess. I ruined a shirt and a pair of gloves doing it. Its going to suck taking mine back apart again so i can have the inside plastic chromed.
Sounds like the rear tails are a PETA....
#35
My good friend has the Micro-tech on his CA powered 240 and it is a nice system. Also, in Austin,tx we have a Fcon Pro tuner. To bad for you guys with that. Sounds like your set-up should be fun. I would like to see the numbers it puts down.
#37
Is the auto rated to hold that much power without slippage...
#38
Mine slips now at 275rwhp. I'm going GM TH700r4, or if i want to be a baller, a 4l60e with stand alone tranny managment, but probably not.
#39
Order the Bosst Logic Built TH400 that will handle 1200 HP
I need overdrive. TCI makes a great TH700r4 that is tested for 600+hp all day use for 2k, but even a stock mild upgraded 700r4 will handle the occassional pass at the track without issue.
#40
#41
I get all my JDM parts from J Hot Imports in Augusta, GA. They are not a middle man, their parts come directly from their recycling plant in Japan.
#42
#45
Originally Posted by 933005spd
looks good. did you get the powders?
Eastwood is good for solids, and caswell has some freakin sick candys
250-awd
06-12-07 07:01 PM
