sc300 foglight question
Originally Posted by akdmks
to help with all this can you juss post the year of your vehicle.
also,what type of bulbs did you use?
check your fuses inside the car behind the drivers side kick panel
1995+ SC300/400 = H3 Halogen Foglights.
you shouldn't need to remove the housing to change the bulb, but if you must, there are 3 bolts on it. Two on the backside, one on the top thats kind of weird to reach. Easiest way is to go in from underneath by removing the brush guard bolts and reaching up. If you're hands are small enough, you can try through the front bumper.
sleepybobcat
03-02-02 02:34 PM
