front left inner fender wire harness
you guys that moved it, how did you move it? did you remove teh fender and route it through the hood? Mine seems to be gettin all chewed up from rubbing. I need to move it.
Keeper of the light
Din, I have been pulling that exact harness along with the rest of the car harness for 17 hours. My SC400 is finally harnes free in every way.
Since I have this fresh in my mind.........
The airbag harness runs along the inner fender to the front of the inside fender, you are rubbing that also. (that's bad MOJO bro)
There is no slack whatsoever in either harness, so what I would suggest is finding a way to keep it off the airbag harness in the fender because you cannot move it. It runs straight to the airbag sensor at the furthermost point of the fender behind the corner of the headlight.
PS, here is the harness.... you can pick it out in this pic.
I moved my driver side fender harnesws above the lip on the chassis. I did this with the fender installed and just took the splash guard off and cut off the factory clips and then ziptied the harness up above.
well mine is all chewed up so wires are exposed, what i was planing on doing was cuttin each one one by one then running it somewhere else then connecting it again. This might take awhile. I was thinking about running the wires thru the hood area then back.
about the air bag ones i guess ima have to figure that out when i got teh fender off.
OLT thats alot of harness u have there.
With 19x9.5 I haven't had a problem with the main harness. Mine is bent up and out of the way so that the tire would hit metal first. yay!
I did however re route the harness that attaches to the windshield washer reservoir/pump.
There were 3 plugs attached to the harness. 2 of them I re routed behind the bottle. One I had to cut/splice to lengthen and re route. No more rubbing there
Im guessing this is the same loom that runs along the right hand side of my car (aussie). If so, all i did was cut the entire loom in half and re-routed it through the engine bay, soldered, taped and then wrapped in split-loom.
Keeper of the light
Originally Posted by demik
my tires ate my fender hanress and now my car wont start even tho i put the wires back to gether
but im gonna find a way to relocate that airbag wire.
Originally Posted by O. L. T.
Which side of the car?
i found out that that it ripped the starter signal ground from a plug so i just made another ground and it works.. and now my oil light and rear light malfuntion light dont go on when i press the clutch
I pulled off the fender and cut a notch in the top part of the fenderwell. I rerouted the wiring above so it runs above the actual inner fender well. No need to extend any wires. I had to do this in my SC and the supra.
