what is the weight of our car?
do you guys know the actual weight of our cars?
the reason i ask is that i hooked up the blitz power meter id and it needs the actual weight of the car in pounds in order to calibrate actual horsepower the car is putting out.
i inputted 4445 lbs but i am not sure if that is accurate espclly i am running 19's, boom box in trunk and all. i test drove the car with the meter and ran a speed of 45mph in 2nd gear the it read "274hp" after the run. i am not sure if that's accurate. any help wud be appreciated.
tks
tks
from http://www.intellexual.net/faq.html#01
SC300
Curb weight ranges from 3494 lbs. in 1992 to 3560 lbs. in 2000.
SC400
Curb weight ranges from 3575 lbs. in 1992 to 3655 lbs. in 2000.
SC300
SC400
wow, tks for infos....i knew i inputted the wrong weight on the meter itself.
ok, so let's just assume the weight of stock sc300 is 3500lbs. with my added mods below:
-2jzgte (heavier than stock, that's for sure)
-19'wheels (anyone care to input? 25-35 lbs each maybe?)
-subwoofer box (12inch woofer, maybe betwen 5-10 lbs?)
-LS brakes and rotors ? (it's heavier, right?)
-2 amps (darn, i gotta weigh that too?)
what would be the estimate weight?
between 400-700 lbs maybe? i just want to get a closer estimate ...
my wheels are not chrome. just regular finish.
so, 250lbs more then? hmm, probably more?
damn, i will just prolly add 500 lbs on top of that....so 3500 + 500 = 4000lbs
at lest it would be better than what i had with "4445 lbs"....hehe
i know what i will do, i will drive to one of those recycler center that have the weight scale...hahaha
i even forgot about my intercooler and piping.......they all add some weight........damn
Originally Posted by chitwnsazn
there's no way your car would way 3500 lbs with all that stuff in it. My stock sc300 weighed in at 3890 lbs when i took it to the emissions testing.
His car has the 2jzgte big turbo and intercooler, brakes and weighs in at 3850lbs with driver. Yuors should be about the same + a few lbs for the stereo
Originally Posted by quikturbo
car weighs 3850lbs with me in it, so that is definitely full weight!!!!
Man, I have to thank Dustin of Chitownracing.com for the great video!!! I'll have the other pass up of me running the 9.61 in the other lane. It came out of the hole awesome, but not like THAT!!!!!
The car should be named Shotgun
Chris
Chris
