Lowered SCs, question about oil change
You guys that are lowered, can you still get your car up on ramps without scraping the front bump? I don't have any ramps, but I do need to do an oil change and I don't know if using my jack + jack stands will raise the car properly enough to drain out all of the old oil. I don't want to buy ramps to not be able to get up on them.
Also, I know it's been discussed, but what filters do you guys use? Lexus wants $13 for a stock filter Can I just go to Toyota and ask for a 94+ Supra oil filter (part #)?
lol yep lifts are the way to go, im gald my dad finnaly invested in one. Now if only our shop was as clean as yours.......Could you just test the ramps out before you bought them???
Thanks all, I will try getting one ramp and turning the wheel fully to the left and driving up on just that one ramp. That should bring the car up enough on the driver side to drain all the oil, otherwise I will use PERRY's method
Wow. Who suggested that?
That may work, but others have warned that opening the door with the car all twisted like that is asking for trouble.
I'm biased, of course, but you'd do well to find some scrap wood "pre-ramps" and raise the front evenly.
Easier to remove the bottom shroud that way, too, if you are so inclined.
I might just do the pre-ramp thing, that's if I don't get lazy by then and just use the jack/jack stands.
I use the Griot's Garage Oil/liquid extractor. No lift, no ramps... As for the oil filter, you can reach in, grab, twist off, and replace from the top of the car.
I do it all the time that way... I see no problem your chassis is suppose to flex, I’m slammed so every time I go into a shopping center the body flexes 10x more than when I do oil changes... I usually get one wheel off the ground when I have to get into steep shopping centers...
Yeah but when you're pulling into a shopping center your door is still closed.
I also have not had problems opening the door while the car is being lifted from one corner, I'm just echoing what others have posted.
Originally Posted by NYLexSC
what filters do you guys use? Lexus wants $13 for a stock filter. Can I just go to Toyota and ask for a 94+ Supra oil filter (part #)?
Why not just use a normal jack to lift the car, and shove a jack stand for extra support / security?
My car is lowered about 2" up front, and 1.7" in the rear (Supra TT Eibach springs & Supra TT KYB Struts)... I still have no problems jacking it up.
-Allen
-Allen
-Allen
-Allen
