1992 SC300 Headlight removal?
I know the housing is plastic and do not want to break any of the fasteners. How do you remove the headlight and how many screw keep it attached.
Thanks
Thanks
Pop the hood...there is one 10mm bolt right on top of the headlight that has to come off.
Then go to your wheel well, pull back the fender liner and reach in there until you are near where the back of the headlight would be. there are two 10mm hexnuts there, one on top of the other. both of those have to come off and then you can pull the headlight out from the front with a little effort.
Total hexnuts per headlight that have to come off: 3.
