Delining
Gang:
I know there are threads on delining headlights, but does anybody have a step by step pictorial and process for delining our headlights? I am interested in just delining the section in front of the projectors of our headlights...
Thanks,
Ryan
Thanks,
Ryan
I'm sure it's in regards to this thread: https://www.clublexus.com/forums/sho...light=Delining
Obviously you pop them in the oven 175-200 def F for 5-10 minutes, and then work from there
Here's a good start from the supra guys:
From MDSUPERSTAR on SF:
"Sand everything out with 400 grit, then 100, then 600, 800, 1000, 1500, 2000, then anything you can find that is higher than that. Then Novus 3 stage plastic polish."
I've used 3M plastic cleaner & polish and it seems to work quite well.
Here's a MKIV.com how-to on cleaning, just sand a little harder to deline![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
http://mkiv.com/techarticles/headlights/index.html
John
John
Originally Posted by SC400TT
Gang:
Thanks,
Ryan
Thanks,
Ryan
Jonny
"Sand everything out with 60 grit, then 100, then 220, 300, 400, 600, 800, 1000, 1500, 2000, then anything you can find that is higher than that. Then Novus 3 stage plastic polish."
John
John
Originally Posted by xirforever
60 grit? wow. i wouldnt touch it with anything less than 400. I started with 600, took forever but the results are amazing.
It will take longer, but it's safer. 60-grit is so aggressive that one bad move and you have a scratch you are dealing with for life.
Thanks Jose & Xir -- as I mentioned above, I quoted that from a post on SF (since a link wouldn't help with their registration somewhat closed)
I'll edit my post to remove the 60 grit![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I personally used 800 & 2000 to wet sand the outside of my headlights. Took a while, but it got the job done.
John
John
