Interior lights
Banned - could not follow forum rules
Interior lighting for your cluster, stereo, climate control would be "Lextech lighting" and that is where I got my upgrades done.
If you got skills remove all the bulbs yourself and match and change accordingly...
I would like to know where I can get a cheap LCD climate control replacement screen?....Mine is doing the blackening thing in the corners and it is starting to **** me off........ or
One more thing I got ultra bright white needles and back ground lighting on my cluster and it illuminates better then I would have thought. Lex tech does not use bulbs either to illuminate the background lighting...Some kind of advanced type of illuminating circuitry. So it is a good deal for what you get and the work that is involved from LEX TECH LIGHTING.... I also will be sending in my stereo, and climate control to Lextech shortly for matching back ground lighting. I first need to replace my blackening climate control LCD screen.......Here is a pic of my cluster, I took this picure on a bright sunny day....At night it looks even better....
Originally Posted by O. L. T.
No they are not, and I do not know why I see someone say that at least once a month.
But maybe you should go another route.
Listen to O.L.T. he is a master at this lighting stuff, and probably knows more then anyone on this and other forums about it......I kid you not.....
Keeper of the light
Originally Posted by BigWaveSC
Sorry dude, But thats what I used and they worked.
Keeper of the light
These are the only two bulbs that will fit in your speedometer. I think someone tried a 74 once because the base would fit, but it is nearly dark because they are very dull.
The 24 is the proper bulb.
