Passenger Door replacement motor
Just replaced pass door regulator motor......window was stuck down
Anyone know if there is a specific way to replace the motor to the regulator arm. Does it mater where the gears mess with the arm ? Does the window have to be up all the way or can it be half way up when parts replaced . Window seems snug by hand to move I was going to lube all moving parts.
Is it normal to be vry snug and tight to the rubber molding? Wondering if that caused the motor mechanism to fail.
I pushed the window up all the way and it is snug allmost stuck as to say.
It's been like that till I got the replacement parts .
Will put them in today!
Neu`roc´i`ty
Check these out. Search button is a friend to us all!!!!
https://www.clublexus.com/forums/sho...r+window+motor
https://www.clublexus.com/forums/sea...earchid=651744
soulsoarer
SC- 1st Gen (1992-2000)
12-26-09 12:17 AM
raceonusa
09-06-05 06:02 PM
