Door won't open from the outside
hey guys, as the title says, the passenger door on my sc won't open from the outside of the car. i could only open it from the inside which makes it a hassle. also, the window on that door will only go down halfway before it stops. anyone have any suggestions on what to do? i got it fixed before, but i want to try to save some money and see if i could fix this problem myself. any information would be appreciated and thanks in advance.
Keeper of the light
My suggestion is to search "Door won't open from the outside" as you titled the thread because that is what everyone else titles the thread when their door didn't open from the outside and I remember 4 threads just this year alone
its probably the plastic piece inside the door.
here is the link
https://www.clublexus.com/forums/sho...or+handle+work
here is the link
Originally Posted by blisiono
thanks for the tip you guys. i guess i have no choice but to buy a whole new part for that door. thanks again for the help!
yeah, i just realized that after looking through the link. i just popped it open too. didn't seem too hard. dang, and i got charged 100 somethin for the same problem like a year ago. only if i knew...
![](http://www.shanghaiist.com/attachments/shang_dan/The_More_You_Know.jpg)
Originally Posted by racinstyle
dude the part is like $3...and its pretty easy to fix
crap, I thought it was less than a dollar... I guess spraying clear coat without a mask really does kill brain cells!
John
bad news, i got the whole thing put together by myself. the next day, it was working fine until i opened my window and i heard something break. when i checked it out, i found out that the metal rod that the plastic piece connects on to snapped. a brand new part is about 400 dollars. does anyone know where i can find the door latch mechanism for cheap becaues the metal rod itself can't be replaced, the entire door opening mechanism has to be replaced which is a pain.
If you didn't fix your door yet, it is very simple. The same thing happened to my sc 400 and all you have to do is take off the door pannel and there is a small plastic piece that has fallen off the door handle which is knocking against the window and wont let it go down. Clip the piece back and you should be ok. It should take no longer then 20 minutes. It should be a white plastic clip. And if the clip is broken you can just simply zip-tie it together. It works. And it is cheap to do.
hey guys, thanks for the help. it's now fixed. the door lock/latch mechanism thing that i bought from the junkyard had no power locks, so my dad decided to fix the old one by welding the snapped rod back together. now my door is working fine. thanks for the help again!
bagyo
SC- 1st Gen (1992-2000)
06-28-13 03:29 PM
