Lights out for my 1995 SC400
Hello,
I have a 1995 Lexus Sc400, my rear view mirror electric cable was cut. ( electric auto dim power cable.) I tried to re-wire it, but my splicer wrench touched the cable to cause a spark. Now my Dome lights don't work along with, my vanity mirrors, when I turn the car off/ pull the key out of the ingnition, my odometor & clock reset every time. Just the trip odometer, not the overall millage,& most of all now my keyless entry doesn't even work. How do I fix this, & also what happened to cause this? Any help from any one any where would be greatly accepted.
Thank you,
Patrick
Thank you,
Patrick
Last edited by PWESC400; 07-15-06 at 12:09 AM. Reason: forgot to add one more thing
When something gets cut like that and sparks come out, a surge goes through the electrical system. You have fuses to protect anything from getting harmed. CHECK YOUR FUSES. Most likely one of them blew out. If you don't know how to check them post back.
Make sure to check both fuse areas.
