No one sells a good car anymore
#31
True....but if you have a warranty like I do then you'll scream bloody murder for them to pick up full Mazda price, then go single or to higher flowing twins with all that $.
Hoses popping off is a problem, worse on some cars than others. My car only had one hose that would pop off. *knock on wood* Fortunately it was the easiest one to access in the whole engine bay, so I zip tied it, no more probs. It runs $3-400 to have all the lines changed to silicone and zip tie them. Some even put sealant on there as you describe, but its optional if zip tied. There are ~80 pieces of small vacuum line in the engine bay, 9 solenoids, 3 actuators on the turbos alone, and 3 vacuum/pressure resirvoirs. At least half of that is for controlling the sequential operation of the turbos.
#32
WOW!!! That's a lot of vacuum lines.... Zip ties hmmmmmmm sounds good...
What does your "7" do in the 1/4??? 13.2 - 13.6 stock or is yours modded?
#33
No offense to anyone to anyone who owns one, but RX-7s are probably among the WORST built sports cars on the road (third generation, anyway). I bought a NEW 94 RX-7 and had nothing but problems until I got rid of it three years later for a 95 Supra. Among the crap I dealt with:
1) The second turbo died at 26K miles.
2) The plastic door handle inside the car broke off at 28K miles.
3) Cats replaced at 30K miles
4) Getting all those damn TSBs taken care of
5) Coolent system problems (caps, filler necks, etc.)
6) Replacing more hoses than I care to remember
4) Not to mention the numerous rattles and squeeks that Mazda couldn't pinpoint.
If you're considering buying a rotary, STAY AWAY!!
Lance
98 SC400
95 Supra TT Hardtop
94 RX-7 (Gone, thankfully)
93 MR-2 Turbo (Gone, but missed)
91 RX-7 (Gone, no problems with this one)
Lance
98 SC400
95 Supra TT Hardtop
#34
#35
The range that you state is indeed par for stock cars.
Forrest
Current:
1994 RX-7 Touring "Lukas"
1990 Dodge P/U "POS"
Past:
1987 RX-7 TurboII "Little Baby Seven"
1986 Dodge Caravan "Little Flying Box"
#36
w00t
Hehe, I started a hell of a discussion here. This is great though... I had considered an RX-7 but I've seen enough people hatin' on them to decide against it. I think I might go for looking out of state on a Supra, but I am patient enough to try the SC300 turbo route. I used to own a Nissan 240SX and the thing was the most reliable car I've ever had. I know that the 300ZX is a tight fit motor, but can it be easily upgraded? I wouldn't mind going with one of those considering my experience with them. I see them for less money too.
#37
240SX.....silvia
i dont kno that much about the 300zx engine swap into the 240sx.....but if you go that route you might as wel go with the SR20DET silvia motor, single turbo upgrade......ive heard nothing but great things about these 4 bangers...if you ask around almost all the pplz that have gone this route are runnin about 360-440 hp and about 10-12sec on tha 1/4 mile(not too sure about this)....plus if you convert the front end to the v-spec silvia s-14 or s-15, you will be one of the very exclusive that have an actual unique design that not many other 240sx's have.....all in all it would cost aroud 5-6 g's on all upgrades, but would be a unique car all its own..... thas just my opinion
#39
Originally posted by MadMaxSC400
I meant BUY a 300ZX twin turbo. I used to have a 240.
#40
None of the failures you mention have anything to do with the fact that the car is a rotary...with the possible exception of the cats...but that is easily and inexpensively rectified with a downpipe. They aren't the most reliable cars in the world, but they are some of the best all 'round performers in the world....sexy as hell, too.
I also agree that it is one of the most beautiful cars to come out of Japan, save the funky stock spoiler and door handles.
I hope you didn't take offense to what I wrote, I just get a little steamed talking about the 7 because of (bad) past experience, especially the horrible dealerships. If it was HALF as reliable as my Supra, I wouldn't heistate to get another one. They are definately a kick in the pants (when running)
Lance
98 SC400
#41
i highly reccommend a supra or sc300turbo....the 300zx is a pain in the *** to work on and very sensitive to detonation...ect....also a very short wheel base..they love to spin out.......they can make hp but i never see the cars last.......also hard to get traction.....i dont reccommend rotarys..unless you have a spare motor in the garage at all times...Jeff
#42
Originally posted by Black94RX-7TT
Yeah, they do. A new set of twins from Mazda will run you slightly in excess of $3000...plus a couple $50 stainless exhaust gaskets, plus the oil and water gaskets/o-rings, and you might as well do the oil lines while you're down there....
a new set of twins from rx7store costs $1500
you can buy a T78 turbo kit for $4000?
300zxs are great cars; they are reliable if you take good care of them... the stock bottom end can handle around 650rwhp before you need to upgrade it... its pretty easy to make power on them...
Just get a set of the T28/T3 turbos from Gyro at DSP in Miami and upgraded intercoolers and supporting fuel, etc and you can make 600rwhp easy... and the turbos with manifolds and downpipes cost only $2500... but you have to remove the engine to install them... everything in the Z is a SUPER tight fit...
if you want something to do thats original; do what a friend of mine in town has done... take a 280zx turbo motor and drop it in a 240 or 280Z (not sx) and put a T3/T4 or full T4 turbo on it... this car will run 11s with only 330rwhp because it only weighs 2600lbs... (the 240z weighs 2300lbs)... the L28 engines are very strong and extremely simple to work on
#44
As for spinning out, I would recommend a good racing school to learn how to drive 10/10 of the time, and learning how the zx handles before going all out. Actually, that would be good advice for anyone driving any car at 10/10.
One zx club recommends that new owners of the zx tt take it easy until they get used to the power delivery of it.
#45
yeah; the Z is a badass handling car if you know how to drive it... it has all-wheel-steering and anti-squat suspension
weight transfer in the car is a lot different; and it also is a bit more unbalanced than most cars... if you drive it like a midengined car almost it handles great... it has enough weight in the front to keep from understeering except in extreme situations and will stay planted and helpout with the AWS in the rear...
Its not an Auto-X car most definitely; its too heavy; it would be good for road racing and it excels on the highway... its also VERY comfortable to drive and has an AWSOME seating position that is both low but easy to get out of...
in my RX-7 there is a stretch of really hard turns that I can take at 90mph before the tires start squeeling and the rear starts moving...
i got my Z sideways on the same turn, but the car stayed planted until 100mph because of the AWS; then it started to step out; but it took no effort to keep it in the same spot; so i just went through the turn a little sideways... scary but the car responded beautifully... its also easier to drive than any other car i've ever driven including my SC300
