Tell me who has this body kit.
Originally Posted by Hain
^^Very true. Even though I have a version select kit (also a vertex knockoff), i dont think the fitment would be anywhere near as bad as these v-speed knockoffs. But with work you can get anything to fit, it will just be a PITA.
I did everything myself, including paint. So just the costs for the material, I've already got all the tools.
The only work really needed was just a bit of sanding and grinding, and a little fiberglass. other than that no problems. and fitment is near perfect. no gaps, no flares. nice and snug.
i have the same kit and i threw it on my car. the sideskirts are a tad bit short, but a dremmel tool fixed that. and i have some minor door closing problems but a screw fixed that. and the front well that is another story. the highbeams have to be altered. lucky i have hid and never use the high beams, the sides fit but after 2 weeks of scraping have extra screws in the car, and most of all check the hood line before drilling holes. nothing worse than seeing a huge gap between the bumper and hood. As for the back well i made a mistake of getting drunk when we got to the portion so we know that turned out wrong. 2 hours of work for a cheap kit and at the end of the day i get props with my funky setup. i say next time i will get vertex, but i am sure this kit will be gone after its first drift event, so why pay thousands to crack it?
Originally Posted by jmlex
Can you post pics Hain?
soardrft, I found a screw on the highbeams that I used to adjust the vertical position and make a good fit. Not sure if that is your problem. If you need to adjust it horizontally then I dunno..
1994 LS400
05-17-02 08:42 AM
