SC- 1st Gen (1992-2000)
common repairs for the SC400?
Old 10-10-01, 11:29 PM
TheKevin
TheKevin's Avatar
Default common repairs for the SC400?
What are the most common repairs for the '92/early SC400?
Old 10-11-01, 07:33 AM
BimmerLexus
BimmerLexus's Avatar
Default Common repairs
The dashes go bad...
The Tourgue converter goes bad if the fluid isn't changes regually(15K Miles)
the powersteering leaks(onto the alternator and mealts the harness)
Various dash lights and HAVC lights go out....
Just to name a few!
Joe
1993 SC400
Old 10-11-01, 03:56 PM
TheKevin
TheKevin's Avatar
are these problems that you experienced with your SC4? or have these happened to other people you know with SC4s too?
Old 10-11-01, 06:15 PM
Taka
Taka's Avatar
hey papanature,
I've heard powersteering leak is common problem on sc.
gauge, needle neon go bad as well.
it's not major problems but it gets annoying.
anything else, everyone?
Old 10-11-01, 07:43 PM
VQT
VQT's Avatar
My 93 Green SC400 has all the problems people just list for you and more. Those are the very common problem with SC400 (don't know about SC300). Head lights and brake lights been known to have moisture inside. Noisy sun roof, CD changer, Speakers...
It's just another high price Toyota that's all. Check out any Toyota problems Lexus has those problems too.
Old 10-11-01, 10:48 PM
AutoCoutureSC
AutoCoutureSC's Avatar
My 93 Sc400 has problems too. just the needles flashing, and i just recently replaced the power steering pump, and the heat shield also. can't think of anything else for now..
Old 10-12-01, 04:42 AM
VQT
VQT's Avatar
What's a heat shield? Where is it?
Old 10-12-01, 05:24 AM
markmaz
markmaz's Avatar
Question How to recognize??
Real good information guys. As a fairly new owner of a SC300
I find it very interesting to learn that there are some "more" common repairs that other owners have experienced.
Although we have an SC, we too have moisture in the headlight and a flashing speedometer needle.
My question to those of you with leaking water pumps is this...
what signs if any could a person look for in order to determine if his or her power steering unit needs to be replaced before anything bad happens?
By the way, for all "new" owners of SC 300's or 400's I'd like to add that replacement of the timing belt and water pump on any used car with 90,000 miles or more would be a wise, preventive maintance messure, in fact, our SC goes into our favorite mechanics hands this coming monday for that work, even though there is nothing apparently wrong. This will give you piece of mind for at least the next 60,000 miles. Just do it!
Old 10-12-01, 10:30 AM
VQT
VQT's Avatar
Default Re: How to recognize??
Are you asking about water pump or steering pump?
If you're doing the timing chain, have them change the water pump also, along with couple of seals, idlers...
As for the steering pump, just have to keep an eye on it everytime you check your engine oil. Look for eny wetness below the pump and doew the cover get wet also? If everything is OK, the engine bay should be dry...
Old 10-12-01, 10:43 AM
AutoCoutureSC
Post
good info markmaz. at 60,000 i replace all my belts, hoses, seals, and all fluids. my car is good until about 120,000 before i change anything else. i just got my trans. fluid done at 80,000 so i'm good to go! runs like new!
Old 10-13-01, 09:26 AM
TheKevin
TheKevin's Avatar
but basically, none of these are major problems that would really damage the car?
Old 10-13-01, 10:25 AM
VQT
VQT's Avatar
Only power steering pump leak will make the alternator fail if don't fix in a timely manner.
Old 10-13-01, 08:59 PM
TheKevin
TheKevin's Avatar
alright cool, im just waiting for my settlement money to come in and im probably going to get a SC400 to replace my ****ty integra.
Old 10-13-01, 09:04 PM
TheKevin
TheKevin's Avatar
were there any recalls for any year SC300/400s?
Old 10-16-01, 02:15 AM
black sc
black sc's Avatar
Check out the NHTSA website. I think it is www.nhtsa.com but, not sure. It lists all recalls.
Quick Reply: common repairs for the SC400?
