STEERING wheel upgrade.....
#136
Sorry to bump but I been searching for awhile and im trying to figure out if a 2001 gs300 steering wheel with airbag will fit into my 95 sc300? I know there are dual stage airbags and singles but i probably wont connect the airbag. will the steering wheel bolt up? and will the airbags work if i cut/splice the 2 wires?
TIA
TIA
For the cruise control, if it doesn't plug in, just swap your cruise control from your original wheel.
#137
As the owner of the wheel pictured above I can tell you that there are 2 sizes of single-stage (pre '01) airbags. The larger one that came on 92-97 SC's as well as LS models, and a smaller diameter version that came on RX, GS, and some other Toyota models like Celica, Matrix, and Rav4. To add to the fun there are 3 different connectors that came on the single-stage airbag modules.
I used the small diameter airbag from a '00 Celica and it had a different plug so I used a tool to remove the 1992 airbag pigtail from my original airbag and transferred it onto the Celica bag. It worked fine on the 1992 I have but I have an issue with it in the 1996 model.
I just transferred this wheel/airbag assembly from my 1992 SC400 onto my "new-to-me" 1996 SC400 and this time I have an airbag check-light on my dash. It's an OBD2 car so I'm hoping I can clear it with the scanner tool...
BTW - SAFETY TIP - Unhook your battery and leave it unhooked for at least 30 minutes before attempting to remove an airbag!
so I cut off and splice the old airbag plug??
iam doing a 00 celica bag/wheel into a 1994 sc400
#138
I've read through this whole thread and I don't think once it was asked whether any of these potential replacement wheels have a smaller diameter than the stock SC steering wheels.
Does anyone know if the '00 IS, GS, ES, or RX wheels are smaller in diameter than our enormous SC ones? I have the 3 spoke SC wheel, but like the look of all of these better, just so far as they are a little bit smaller with thicker grip.
#139
#140
#141
