STEERING wheel upgrade.....
#31
Ouote by lighthalo
"i think i saw a few people with the IS wheel on their SC, possible right?
how much modding needs to be done to put it on if any?"
IS300 steering wheel and airbag (stage one) No modifications except if you want cruise you have to use you old cruise control and mod it a bit.
![](http://i6.photobucket.com/albums/y201/soarerjzz30/ExiledLexus017.jpg)
That wheel is exactly what I'm wanting. Did you mod your cruise to work with that wheel? If so what did you have to do?
#32
Yes I used the the cruise from my original wheel. You have to use a dremel and trim the corner otherwise you won't be able to mount it. Be careful, at first I used my skateboard grip tape to shave the corner and expose the internal parts/wires then used a dremel and wrapped everything exposed in electrical tape. Hope this helps.
#33
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
#36
#40
so exactly which wheels will just plug and play. i dont want to go through all that airbag changing stuff. I want somethin nicer oem. i was thinkin like 00-05 rx/es/sc? i believe those are the single stage airbags. idk though, please help me, whats a nice wheel, with airbag that will hook right up
#44
SO I just got a 99 GS400 Steering Wheel and Airbag, what else do I need to attach this to the SC400, do I need the adapter for the airbag plug, do I have to swap my cruise controler out from the GS wheel? Any tips
#45
Former Sponsor
now, the newer airbags, let's say 2000 SC300 steering wheel & airbag, the wheel will fit perfect, but the airbag does't just fit older SC....becuase the yellow plug on the back is different......so do we have to change out the clockspring too?? or what do we do??
