View Poll Results: Shaved or Rolled fenders?
Shaved
28
35.44%
Rolled
51
64.56%
Voters: 79. You may not vote on this poll
The thing about it, if you roll your fenders, as much as you would cut them, ie, to have the full flush effect, the fenders will come out lumpy. I plan to dump mines with stretch tires.
I want my fender to stay clean with no bumps where its rolled. ill try to take pics to show you what i mean.
Maintenance Moderator
it all had to do with how much care you put into the actual process... there is one dent in my rr lip, but that was there prior to rolling the fenders, and is actually less than original now...
the main reason you see those bumps and stuff when people "roll" fenders is because they do it the ghetto way with a baseball bat, and a mallet... use a professional fender roller and it comes out perfect (so long as you take the time to do so...
Cut and grind
Cutting fenders is fairly easy. If you have access to an air saw, you will be able to cut all four in less than 30 min. Of course it will take a little longer as you have to remove the wheels but you do not have to worry about messing up the paint or creasing the fender. Use a grinder to smooth out everything after the cut. And for your enjoyment a 2 yr old pics ha.
and with shaving fender.... NO CHIPPED PAINT. i have seen some nasty fenders from people that roll their fenders... mine are stilll good. u take ur pick. and i dunno y people say that shaving will make then weaker. they are double layered in the back. and the front isnt. but if anything hits ur fenders. its gonna mess them up anyways. i believe u will get ALOT more clearance if u shave them .
I'm leaning towards cutting mines, but I'd like to roll it if possible, Is there anyone that could explain the process of rolling the fenders with out lumps? slow roll with lots of heat, from a heat gun? anyone?
Rubber mallet the inside of the fender lip so that it is flush with the inside of the fenderwall. Make sure you start at one side of your fender and work evenly and entrely across to the other side, as not to skip any spots.
Heat the fender up again, and now slowly, start rolling. You have to roll in steps, not just one or two passes, but a series of rolls, to roll and pull the fender evenly. It will come out good.
*Tip
1) Put electric tape on the fender crease, to preserve the paint, and avoid burning your clearcoat.
2) Try using a rubber mallet with a soft, and hard side, using the hard side when the fender is still hot and the soft side when it starts to cool.
3) Take your time, it takes about 30min to an hour to roll a fender correctly depending on your experience.
Rolled in the rear (shaving would be cleaner, but i like the extra metal up inside), wiring harness relocated on the driver front, plastic and bolts shaved for tire clearance.
I have 315's on the rear with very limited rub. Im going to have the fenders rolled and im actually counting on the paint chipping in the inside. Without plastic to protect the fender its just a matter of time b4 a pebble comes up and chips the paint and starts to rust. Im having primer sprayed in the inside and then undercoating which is similiar to Line X.
