SC- 1st Gen (1992-2000)
Need new headlight
Old 03-03-01, 11:31 AM
Slick Lex Coupe
Slick Lex Coupe's Avatar
I recently got my car back from the bodyshop after a small act of driving stupidity. One of my headlights was replaced. The new headlight looks so nice because it's all crystal clear, shiny and new, but the older one doesn't really match now. It doesn't have the common condensation problem, but it just old looking(not very clear). Does anybody know if I could just get a replacement lens or do I have to get the whole assembly, and how much do they cost? Thanks.
Old 03-03-01, 04:36 PM
reLEXin247
reLEXin247's Avatar
I had the same problem and instead of replacing the headlight, I took it all apart and polished the inside of the old lens with plastic polish. You should be able to find it in a good auto paint supply store. Mine came out great, looks just like the new one. It's just a little time consuming to take the headlight apart. I also did the high beams in the car and they turned out well too.
Old 03-03-01, 06:59 PM
abdul10000
abdul10000's Avatar
Question
Hello Slick Lex Coupe,
I would like, if you don't mind, to know how did you take the headlight apart, and what did you do to put it together. Thanks in advance
Old 03-03-01, 07:01 PM
abdul10000
abdul10000's Avatar
Question
Opss, I ment reLEXin247
Old 03-03-01, 09:43 PM
reLEXin247
reLEXin247's Avatar
to take the headlight apart i had to heat up the seam with a heat gun and gently pry the lens off the housing with a med sized flat screwdriver. Be careful not to pry too hard or you could chip the lens.
Old 03-04-01, 03:57 AM
abdul10000
abdul10000's Avatar
Thanks, and what did you use to put it together.
Old 03-04-01, 05:44 AM
Claw
Claw's Avatar
Hi Slick,
I agree with all of the previous postings but would like to add that I had the same problem and did not need to remove or replace the headlight assembly. I was advised to use Meguiars Crystal Paint Cleaner (but plastic polish would work as well as previously noted) with some kitchen paper and after lots of rubbing the other three lights were as clear as the newly replaced one. Most of the oxidisation is on the outside of the light. Anyway I thought it might be worth a try before removing the headlight assembly to clean it cause thats a right pain in the backside.
Claw
Soarer 93 2.5TT
Old 03-04-01, 09:02 AM
reLEXin247
reLEXin247's Avatar
Yeah, sometimes there's just oxidation on the outside of the lens, but I had a small moisture problem on mine and the inside had turned a little dull looking. On my high beams I didn't have any moisture inside but still polished the inside and it looked 100% better. I used regular clear silicone to reseal the lights.
Old 03-04-01, 09:28 AM
abdul10000
abdul10000's Avatar
Many thanks reLEXin247
Old 03-04-01, 06:48 PM
Slick Lex Coupe
Thanks for all the help guys. Once this snow clears out up here I'll be trying out the tips.
Pachino
08-07-20 10:35 AM
A3OD
HS 250h Model (2010-2012)
04-20-19 02:26 PM
Cannonbear
01-24-05 03:23 AM
gsfor
10-25-04 07:45 PM
es3doubleO
09-01-04 07:58 PM
Quick Reply: Need new headlight
