Video of Street Testing turbo SC (merged threads x 3)
GRRRR I cant watch it i need a codec or something all i see is the video all in colors and stuff.. but i can hear it perfectly!
sounds like a beast!!!
p.s. anybody know wat codec im missing bc theres been a few files that i could not watch and its troublesome!
i have divx and ffdhow and crap iono wat else
thanks
thanks
awesome!
C'mon now, I know you all can do better than this. What are ya? Storm troopers or something?
Yes it is.
Engine (2JZGE / 2JZGTE):
2JZ-GE SC300 non-turbo block w/ 2JZ-GTE Supra head
CP Pistons & H-beam Rods ("built supra motor")
ARP head studs and hardware
Crower Cams , Valve springs , Retainers
VC Intake Manifold & 90mm Throttle Body
PTE Turbo on tubular T4 turbo manifold
4inch Stainless Steel Downpipe / Exhaust
Intercooler w/ 3" Aluminum Piping
Tial 44mm Wastegate & 50mm Blow Off Valve
Nitrous Express (NX) direct port wet nitrous
Koyo Race Radiator / 2 Transmission Coolers
Fuel:
Aeromotive Eliminator & Aeromotive 10AN filter
Aeromotive Fuel Pressure Regulator & 1680cc Injectors
10AN fuel lines & 8AN High Flow Fuel Rail
VP Racing C16 Race Gas for high boost
Transmission:
TH400 with transbrake & unlocked converter
B&M Quicksilver Shifter / Hurst Roll Control Line Lock
Spool Locked Differential & 4.27 Lexus Gear
Weld Alumastars / Mickey Thompson ET Drag Tires
HKS Drag Suspension
Electronics:
Electromotive Tec3 Standalone Engine Management
Mappable Boost Control & Progressive Nitrous Control
Wideband O2 Sensor
Safety:
Roll Cage - 10 point chromoly, certified to 8.49
Parachute + Window Net (Detachable)
Transmission Blanket + Driveshaft Loop
Fire Suppression System
Fuel:
Transmission:
HKS Drag Suspension
Electronics:
Wideband O2 Sensor
Safety:
