voltage issues
A very common problem with our cars is the grounding point from the negative battery cable to the frame, next to the battery. I used a multimeter and detected a voltage drop between the negative battery post and the body when running a lot of accessories. I simply picked up a short battery cable with lugs on each end from Advance Auto Parts and connected one end to the bolt on the negative battery post and the other end to the bolt going through the negative battery cable into the body next to the battery. I never had another problem --- and its gotta be at least 5 years now. Hope this helps ...
tavarish
SC- 1st Gen (1992-2000)
25
11-29-22 04:25 PM
RXRodger
05-17-16 07:34 AM
