voltage issues
voltage issues
never saw this before but my cluster lights dim out when i step on the brakes .anybody ever had this issue before? is there a easy fix for it ?
If you think that's bad, mine used to completely restart the entire car. EVERYTHING shut off (electrically) then booted back up.
I searched and yup, bad ground as well. Happy fixing!
gotta check all your grounding points.
well it wasent the ground .some water got in the tailight from a litle crack in the back or it and rusted out all the light sockets some wd40 and new bulbs did the trick looking at the car shown that the owner was very destructive towards it .it has a new owner now .so it will be under some serious tlc thanks for the info though guys
yea it was so rusty i had to break every light soak it with wd40 then take a pliers and yank it out but it was grouding so it was a ground issue
Mortgage Slave
I got similar problem, how do I detect if there are bad grounds?
Today 04:11 AM
Today 04:11 AM
Check to see if your headlights dim too when something electric is turned on (brake lights, headlights, blinkers etc).
