Changing rear gears? Speedo or other problems?
Does changing gears from 3.27 to 3.76 cause any problems with how the ECU functions? Driveability problems? Where/how to get the speedo properly recalibrated? Thanks
Yea so the speedometer will be inaccurate after changing the diff ratio. The speedometer is based on output shaft RPM so if you increase the gear ratio from 3.27 to 3.76 your output shaft will be spinning more for a given speed than before and thus your speedometer will read higher (proportionally to 3.76 divided by 3.27) by approximately 15%.
This post is from 2001.
mtnrat, there is no 3.26 diff. The correct label is 3.266 or rounded up 3.27. You require a speedo calibration device such as a yellow box. But I would advise putting back the stock 3.92 diff. Besides the obvious performance advantage (3.26 is far to tall with the w58's 2nd and 3rd gear ratio) you'll be left with about a 4% error before factoring in tires.
I have been driving the W58 and 3.27 for a while now, close to 3000 miles. It is quicker than the auto ever was and is better for passing. I like the longer gears as I do most of my driving on the hwy. It is what I want for how I drive. If i was ripping around a city I would like the shorter diff, but it is great for what I want. I will look into the yellow box. I put a speed calibrator in my 80 series landcruiser when I put in 4.88 gears and 35" tires. Worked great for that, but I had explicit instructions on which wires to use to make it work for that model.
SorrGwa
11-28-11 08:15 PM
Boergy
Performance & Maintenance
15
12-17-10 10:37 AM
box, changing, correction, error, gears, is300, lexus, r154, rear, recalibrator, sc, speedo, speedometer, swap, yellow
