man i just got these 2day and my lights are going crazy the turnsignal is flicking like a modded civic, is this a quick fix?? some one has to know whats up thanks
all my bulbs are fine i checked them all...i plugs the 95 harness right in 2 my stock harness
That's where the hyperblink comes from I'm pretty sure, because of the difference in current running through the system now as opposed to before. The newer tails use less power since the lights are mostly wedge bulbs instead of filaments, so your car thinks your lights arent there because it doesnt pick up enough resistance, causing the hyperblink.
you can fix it by wiring in the rite resistor or find the right taillight failure module and swap that out for ur stock one. it's located near the antenna assembly in the trunk.
no body knows??? wow all these 95 tails on 92-94 are people content with the hyperblink??
