what gives?? lights are not working...
thanks
Check all the fuses in the drivers side floor well and under the hood in the fuse box. If not I had a similar problem, If someone was installing a stereo they may have loosened a connector in that big cluster of wires hidden behind and under your radio. That will cause this problem as well. Took me a while to figure out which connect as well
The procedures and fuse layout of the fuse boxes is in your owners manual.
Suggest to replace with the exact same fuse amperage if you find one burnt. If a short still exists, it will burn again immediately.
Return the vehicle to the body shop.
wasabishot
10-15-17 06:36 PM
bizzness
05-16-11 11:32 PM
