New member..key not turning in trunk lock
Hey there...new member...owned an SC 400 many years ago...then moved on to bimmers (540/6 speed and e36 M3 which I still have)...just picked up a 93 SC 400 for commuting...Like title says, the key wont even turn in the lock for the trunk...any ideas...tried to spray WD 40 in there but to no avail..thanks
Be sure its not a valet key, and that the lock by the trunk release under the steering wheel is in the unlock position. If your key cannot turn the lock by the trunk release under the steering wheel (or the glove box lock for that matter), then it is for sure a valet key.
Its black, has the remote button, and unlocks the trunk release button inside the car...is there any way the lock could be frozen or rusted from the inside??
You don't know the lock's history. It may not be the original or damaged in collision at one time.
Have a locksmith look at it ... One that understands the lock design.
Hey, I had a similar problem... the key would go in but sometimes wouldn't turn. Sometimes, I'd take it out and put it in 180 and then I'd still have to "jiggle" it a bit to get it to work.
Well, I got tired of this and removed the cover in the trunk to look at it. I found that one of the bolts that hold the lock cylinder in place was very, very loose... to the point that the cylinder was loose. After tightening it up it worked fine.
Ya might give this a try..
I figured I'd bump this thread because I have a similar problem. The trunk release does not work and the lock was missing when I bought the car. I only have the master key and it used to work in the trunk and on the passenger door--now it only works in the driver door and ignition. The funny thing is that my brother used to have an SC and his key would work in my trunk.
Any help on a solution would be appreciated. Thanks.
、无面值邮票: 指各种未印面值的邮票。1941年中华邮政发行过"国内快递"和"国内挂号" 两种无面值单位邮票。 8、盖销票: 从广义上讲,凡是被邮戳盖销了的邮票都是盖销票。但是,邮票公司价目表上的盖销票,指的是将没有使用过的新邮票有意地用邮戳盖销,用来供应集邮者,这种邮票叫盖销邮票。有一部分集邮者喜欢盖销邮票,把盖销票作为一个集邮品种。邮票公司为了满足这部分集邮者的爱好,就供应盖销票。如五十年代的中国集邮公司就曾向国内外集邮者供应过盖销票。盖销票的价格一般低于新票,但有的盖销票价格相当于新票。 9、信销票: 信销票是指实寄信件上被邮戳盖销了的邮票。信销票的出售价格一般低于新票和盖销票。但有的信销票由于发行较早,存在数量稀少,价格昂贵,甚至成为无价之宝,最典型的例子是"红印花小字当壹圆"旧票,这种实寄过的信销票存世仅此一枚,已成为珍贵的历史文物。原由我国著名集邮家刀任全先生收藏,后来刀老将这枚传世孤品捐献给国家,由集邮博物馆收藏。由于信销票容易得到,不用花钱或花钱很少,且有实寄意义,所以对初集邮者提倡从收集信销票开始。 10、对剖票: 因某种面值邮票暂时缺售,为应急将另一种邮票竖向或横向或对角剖开当两枚邮票贴用,其面值按被剖邮票的面值等分出售使用,称为对剖票。如1903年福州邮局因1分票短缺,为了应急就把库存的蟠龙无水印红色2分票斜角对剖当1分票使用。对剖票都是在邮局当面出售贴用,不预售,有的加盖特殊戳记,收集时最好连同实寄封一起收集、保存。 11、"文"字票: 文化大革命发生后,邮票发行工作受到极大干扰,正常工作包括邮票志号的编列工作无法进行,因此,从1967年4月20日发行的《毛主席语录》邮票开始,邮票上原编列的"纪"、"待"、志号被取消,邮票上没有编列志号,但在邮票发行内部仍有编号,从"文1"编起,一直编到"文19",这19套邮票,通称"文"字邮票,共80枚。
