rear speaker access, how?
Hi, I have sc400, but can't figure out how to access to rear speaker..
I tried to access from trunk..but dont think this is right way. do I need to remove the rear seat? is there any screws?
sorry, it's kinda newbie question
It's not a easy. You have to do it from inside. First, you have to remove back seat, then cover panel above speakers and subwoofer, not the individual ones, the whole triangular looking one. Then you have access.
Registered User
I'll just add that this speaker panel (aka "package tray") is easier to take out if you remove the third brake light module first. Just slide it towards you and tilt up and out.
Be careful when removing the package tray. It can become very brittle after a few summers in the hot sun.
-Jon
-Jon
thanks for reply
Can you explain more detail on removing back seat?
I tried pull up the back seat but it doesn't seem to come up. Is there any screws?
thanks for help
thanks for help
Registered User
As I recall there no screws holding down the part you sit on. Just give a good yank from the front edge, they kinda pop out. Once these are removed you'll see the fasteners for the back seat.
If you are lucky you may find a rusty fuse, cracked ballpoint pen, a tarnished nickel, and a used book of matches all under the seat
-Jon
-Jon
Thanks for detail, that's what i needed
by the way, when I access from trunk, there was hole on each side next to speakers, and could easily open it but there was lots of cracked peace of glasses...any idea what it was? gotta check what it was but it wasn't broken window for sure...
hmm anywayz, thanks for help again
It's tight back in the Lexus coupe, but I urrrrrrrrr ummmmmm "heard" it is quite possible ... To enjoy a comfy "RIDE"....
The Ikon
ha ha ha ha ha ha ha
I bought my SC from the mayor of Corinth, MS a few years ago and I hope he and the Mrs. did not relive their youth in my SC either. But if they did what the hell!!!!
What type of speakers are you putting in the rear? Do you have the "Nakimichi Premium system" of the "pioneer" based unit? I'm thinking that's why the speakers are different sizes in the rear of some coupes.(I'm not sure just speculating...)
Let me know what size speakers you have and the type of system too.
I have Nak sys but haven't looked at rear speaker yet so dont know what size they are. I think 4".
Before I get MB Quart for front, I wanna swap rear one to front because I have problem with hiss noise on certain music I have( and AM radio). Probably it's my CD-R but if not, gotta work on the cables on rear speakers..
how is your speakers? did you get new speakers yet?
actually I haven't decide which speaker I'm going for.
-Jon
-Jon
Hey Ikon, I was wondering where that went!!! Sorry bout' the stains on the seat.
To remove the rear vertical coushins, just push in to the rear of the car and pull them up. Keep an eye on the seat belts. Once the seat is out, this will expose 2 loose unidentified self tapping silver screws that did not come with the vehicle. The lucky ones have a shiney 10mm nut glistening in the light which appears to be OEM. Though every exhaustable effort is used to determine the origin of this nut, nothing is found. So it lay there, alone in the vast wasteland of dried out fly,mosquito, and love bug carcasses; covered in dust. Oddly, when you re-install the seat; the nut is left for the next unsuspecting owner to encounter!
It's leather so it was OK!
Sounds easy enough on the rear seat removal. Keith what size speakers are in the rear of your car, 4" or 6 1/2"? The rear speaker cover is really big for a 4" but I would not be surprised if the computer in Circuit City and Best Buy was wrong about the size for the speakers in the rear.
I'm on hold with Crutchfield now to verify the speaker sizes in the rear.
