Glue
Glue
I need some help. I am trying to glue a hard plastic to the inside of my car. Below the steering wheel where your feet are. The material that the car is made out of is like a hard plastic kinds slippery, you all know what i am talking about. Its the material most of the interior is moulding stuff is made of. I have tried everything i can think of!! Glue, Epoxy, tape, ducttape, everything. those pad things that are sticky on both sides. I cant figure it out!!! Any ideas at all????
hmm, i have had luck with those epoxy things at home depot when there is 2 tubes that you have to mix together, just make sure you follow the instructions well, sand down both parts to make it ruff, clamp it together and leave it for 24hrs, you shouldnt have a problem, if you can put a screw through it with the epoxy and you will be good to go
machefai
04-09-11 05:18 AM
