side marker lights...
Take off the bolts that hold the fender lining in the wheel well and pull it back. Then you can reach in there and twist the bulb out to replace it. Kind of annoying to get to it if you have larger hands, but its doable.
thanks, i have to change mind also, i thought to do that, but didn't, now i will
Since the thread is similar, i figure i might as well ask, to remove the entire sidemarker, i assume i just slide in a screwdriver at the sides and pop it up? Just wanna make sure before i Fudge something up.
there are 2 8mm bolts on either side of the back of the sidemarker, you need to remove those then it will just fall out. They are kind of tedious to get to, but you can do it easily if you jack the wheel up
