Help Key wont go in!
Before, the key slides in the ignition w/o problems. Now, it wont. I disconnected the baterry a few times and it still wouldnt go in. It only goes half way. There's nothing stuck inside the ignition key hole. I dont know if it has something to do with it having an aftermarket alarm, or that I am stripping the interior. Help!!!
Any hardware store (like an OSH or ACE hardware) will have it. Also, any locksmith will have it.
It is a small tube of dry graphite powder. You squeeze it into the cylinders to lube the teeth.
