converting 93 to 97+ tail lights
It's not a straight swap as a lot of others will lead you to believe. In my case I needed a drill, a dremel, and some other hand tools to complete the job correctly.
On the backside of the tails there are these 4 little screws which have to go into holes in the sheet metel on the rear of your car where the tails sit. The screws are like pegs and must be aligned properly in order to wedge the taillight in there. On the 92-94 tails the screws are configured slightly differently than on the 97 tails so you will need a drill/dremel to either lengthen the holes in the sheet metal on your car so the tail light can slide in easily...or to drill completely new holes. You decide.
It's not hard but DO NOT start this job unless you have a drill and dremel handy
Not to mention the infamous resulting hyperblink!
you also have to drill new holes for the 97 tails on the 92-94 body style i believe. i'm going to try a load resistor for the turn signal, and just remove the brake indicator light
ummmmm just curious but did you buy a 97+ front BUMPER too? Because otherwise you can't fit the fogs or the grill into the earlier style bumper...
Some people like to use the "just force it in" method but that's not for me, especially when I'm installing some new 97 tails where the plastic could crack or a seal could be broken. No thanks, I'll just drill
