Lights in Speedo Cluster Out? (odometer cathode is bad)
My whole dash is out now. I know I can send it off to get the leds fixed, but the one thing im not sure of is the lights that show the mileage on the car. Mines is totally out is there a fix for this or should just get a whole new cluster?
Keeper of the light
you'll need a new cluster or find a new ODO. (not very likely).
That is a heater element, when it goes bad the grid no longer heats the cathode and it fails to light. if you look very very close you'll see the heater element. I detailed this in the ice blue thread up there showing you the parts of the cluster.
good luck on your search.
Keeper of the light
you can use any SC odo you can find. it just plugs into the board. Here, I just sifted through 1100 posts to find this.
https://www.clublexus.com/forums/sho...&postcount=273
Keeper of the light
PS- don't blow the bank trying to find an ODO unit, just grab a cheapie if you see one around because there is a TINY chance the board of the cluster has a flaw, but usually the odo grid burns out.
Both are rare.
Both are rare.
j stuff
17
01-22-08 06:04 PM
